P pete123edgar Honorable Feb 8, 2013 305 0 10,810 Mar 8, 2013 #2 I think you meant 192.168.0.1, for me its 0.1 not 1.1 try that. Upvote 0 Downvote
B bookwormsy Distinguished Jun 18, 2011 136 0 18,690 Mar 8, 2013 #3 Go to command prompt and type ipconfig. (windows) Go to Terminal and type ifconfig. (mac) See whats under "gateway" Thats the router. Upvote 0 Downvote
scout_03 Titan Ambassador Feb 18, 2010 30,566 321 107,640 Mar 8, 2013 #4 ususaly you use your browser check the model of your router to see if you use the right number it is in the user manual or do a factory reset . Upvote 0 Downvote
ZachSmiith Honorable Mar 8, 2013 5 0 10,510 Mar 8, 2013 #5 the R : unable to pull my Ip address 192.168.1.1 up I would advise using the "ipconfig" tool within cmd to find the gateway. If you are running via a BT Home Hub then it will be 192.168.1.254. Upvote 0 Downvote
