Need help, Looking to build a pc for 450-500
tashtgf
15
Hi guys, could you help me please,
looking to build my first gaming pc for about 450-500
mostly playing WOT and CS
no monitor/keyboar/mouse is required, also i do have Hard drives, so no need to include them.
Also could you advise whether to have Intel or AMD?
Thank You.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor (£97.98 @ Ebuyer)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard (£49.99 @ Novatech)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory (£32.88 @ Ebuyer)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£37.98 @ Novatech)
Video Card: MSI GeForce GTX 960 4GB Video Card (£169.99 @ Amazon UK)
Case: Corsair SPEC-01 RED ATX Mid Tower Case (£42.99 @ Ebuyer)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply (£70.97 @ Amazon UK)
Total: £502.78
Generated by PCPartPicker 2016-04-12 20:04 BST+0100
We can get rid off the hard drive as i do have also, will there be any i5 cpu or i3-6100 is good enough?
yes but i would recomend getting an i5 if you can, it will make a big difference and it means that you can upgrade your gpu a few years down the line without having to touch the rest of your system. a 6400 will do the trick as long as its an i5, with that said a 6600k will be a large step up from that again but with the budget that your on id get a 6400.
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor (£152.99 @ Ebuyer)
Total: £519.81
Generated by PCPartPicker 2016-04-12 20:19 BST+0100
Hi, thanks for the pick, just a quick question, what if we change cpu i5 6400 for if 6500 and is there is an alternative for power supply a bit cheaper? also adding a cpu cooler?
Thanks
changing the cpu wont make much of a difference, if you want to spend more i would get an ssd.
you need atleast 550 watts and i would definetly not cheap out on the psu.
you cannot overclock your cpu so a stock cooler is fine.
