Hi! I've been buying used parts for a budget gaming build, and I have (at least) a problem at the moment. My motherboard (MSI B250M PRO VD, micro atx) has only a sys header and a cpu header for the fans, and the case I bought (stormtrooper) has two intake fans on the front and a bigger fan on the top. I obviously would have to buy a splitter and connect them all in the same header, thus sacrificing fan control, as the support at MSI told me, but is it safe? And most importantly, in case it is better to only connect one fan, would that be enough cooling for my current build, as well as for the next intended build(Gpu/cpu/extra ram)?
My current build is:
Cpu: g4560
Gpu: Rx 560 4gb
Ram: 1×8gb ddr4 2400 (hyperx fury)
SSD: samsung evo 250
PSU: EVGA 750GQ
MoBo: MSI B250M PRO VD
The planned upgrade would be same as above, except for:
Cpu: i7 7800x
Gpu: Gtx 1080 ti
Ram: 2x 8gb ddr4 2400 (HyperX Fury)
Thanks in advance, bear with me, it's my first try at building a pc, and I certainly have many faults and misconceptions about how to endeavor in this path
Cpu: g4560
Gpu: Rx 560 4gb
PSU: EVGA 750GQ
Cpu: i7 7800x
Gpu: Gtx 1080 ti
