Need help on a arma 3 pc build
slimhim
4
Looking for a build in the $1000-1200 range to play some arma 3 on. will need a os and wireless. anyone wanna give it a shot?
Of course not, haha, but since you only said 1000-2000, I tried to make you an optimized build for the middle of your price range. You could probably cut a couple hundreds bucks on it.
This would also be fine, and you could invest in an SSD later, since it isn't mendatory. It also has a GTX970 instead of the 980, which is still an amazing card!
http://pcpartpicker.com/p/7Mw4rH
