Need help on a build XEon or i7
Pix3l
7
Build:
GTX780Ti
Corsair AX1500i PSU
ASUS Z10PE-D8 WS
Crucial 32GB DDR4 2133 CT4K8G4RFS4213
Samsung 840 EVO 500Gb
Crucial M550 512 GB M.2
Dual Xeon E5-2620 v3 (2011-3)
Should i go for this $4000 build or is there a better option with the new i7 8core (5960X)?
I dont really game, just editing (AE, CC pro, PS, Ai, Cinema 4D, 3ds)
Really need help on this
Thank you in advance
From the research I've conducted, most consumer software (ie: Sony, Adobe, and so on) don't really benefit too much from having computers with more than four physical cores (like the 4790k). The software is designed to utilise a certain amount of threads, and having more won't actually speed anything up; there's kind of nothing you can do about this, aside from switching software. Most consumer software I've seen doesn't really support more than 8 threads (my research could very well be wrong). If you're actually looking at what computer would perform better with which CPU, then shoot an email to Adobe. I'm willing to be Adobe CC will perform nearly identical with either the dual Xeon, or the 5960x, as they both are just not what the...
If you have the money to blow
CPU: Intel Core i7-5960X 3.0GHz 8-Core Processor ($1049.99 @ Newegg)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler ($129.99 @ SuperBiiz)
Motherboard: Asus X99-DELUXE ATX LGA2011-3 Motherboard ($386.75 @ Newegg)
Memory: G.Skill Ripjaws Series 32GB (4 x 8GB) DDR4-2400 Memory ($519.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive ($119.99 @ Amazon)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($101.47 @ Amazon)
Video Card: XFX Radeon R9 295X2 8GB Core Edition Video Card ($799.99 @ Newegg)
Case: Corsair 750D ATX Full Tower Case ($119.99 @ Newegg)
Power Supply: SeaSonic X Series 1250W 80+ Gold Certified Fully-Modular ATX Power Supply ($218.99 @ SuperBiiz)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer ($13.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Total: $3621.11
Generated by PCPartPicker 2014-11-17 23:57 EST-0500
not bad ! sammy, but i have another question for you .
In adobe cc pro will this render much faster then the xeon build?
Does adobe prefer open cl over cuda?
From the research I've conducted, most consumer software (ie: Sony, Adobe, and so on) don't really benefit too much from having computers with more than four physical cores (like the 4790k). The software is designed to utilise a certain amount of threads, and having more won't actually speed anything up; there's kind of nothing you can do about this, aside from switching software. Most consumer software I've seen doesn't really support more than 8 threads (my research could very well be wrong). If you're actually looking at what computer would perform better with which CPU, then shoot an email to Adobe. I'm willing to be Adobe CC will perform nearly identical with either the dual Xeon, or the 5960x, as they both are just not what the software is designed to utilise.
With that said, in this article, it seems like CUDA processing is more natively supported by Adobe. This is an outdated article, but it does make the point that they've been supporting the CUDA technology natively for a bit longer than OpenCL; so I'd consider going the NVIDIA route for your GPU. Personally, I would prefer NVIDIA, as the AMD cards just don't seem to be supported as well with most things. They may work "fine" or "okay," but compared side-by-side, I'm willing to bet the NVIDIA cards would be notably smoother. Could be wrong, but that's what my research has led me to believe.
As far as your build is concerned, I don't see why you should consider going with an i7, if you're looking for maximum calculation power. You will have more brute force with dual Xeons, as you will have 24 threads at your command, whereas the i7 will only give you 16. Yes, you will benefit in some ways with a higher clock speed, but it also depends on what you're doing. In theory, if you were to match both the dual Xeon setup with the 5960x, in a video rendering test, the extra threads would help your Xeons get everything done faster. Just an example, though.
