My part list is below.
i7-7700K-(CPU)
GIGABYTE AORUS GA-Z270X-Gaming 7-(MOTHERBOARD)
G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 4133-(RAM)
MSI 1080Ti-(GPU)
Samsung 960 EVO M.2 500GB-(SSD) (I already own this so its already got Windows 10 on it.)
CORSAIR Crystal 570X RGB WHITE-(CASE)
SeaSonic Snow Silent-1050 1050W ATX12V / EPS12V 80 PLUS PLATINUM-(PSU)
The question is, is do i need a motherboard and PSU like the ones i picked out? I will just be gaming only and not ever do SLI and no extreme overclocking, just a small amount. So should i get a cheaper PSU and Motherboard? I think the PSU may be to powerful because i know a 1080Ti wont use anywhere near 1050W. I do want the PSU to be 80+ Platinum though. I will be upgrading from my i5-4690/MSI 980Ti Golden/ 4x4GB 1600MHz Ram system. I also have a 80+ Bronze Module PSU with it. I play at 1080p also but i may upgrade to 1440p if the new system can handle playing games at ultra settings at that resolution with 60+FPS at least but if not, ill stick with 1080p.
i7-7700K-(CPU)
MSI 1080Ti-(GPU)
