[SOLVED] Need help on choosing Cabinet for AMD Ryzen 2700X build
Mar 18, 2019
17
Hello people !!
I really in need of suggestions for my Gaming&Streaming PC build plan. I have a well researched plan for my first PC build. Everything seems good except one thing. THE CABINET !!
I am not sure which cabinet I can go for. I really look into cooling performance. I saw many cabinets with pre-installed Fans but not sure which one to choose.
Here is my build plan. Have a look into it and suggest a good case for it.
CPU - AMD Ryzen 2700X
GPU - RTX 2060 by MSI
Mobo - MSI X470 gaming plus
RAM - Corsair Vengeance LPX CMK32GX4M2B3200C16 (2x16 GB) dual channel [checked the mobo QVL, it is compatible]
SSD - WD SATA III 6 Gb/s, M.2 2280 500GB
HDD - Seagate Baracuda 1TB
Cooling - Ryzen Wraith Prism cooler [for now]
All the parts are compatible with the mobo.
Suggest a good Case considering my build list.
6000 rupees gives you a lot of options.
While there are many options available, current trends do tend to limit airflow.
For example, this case (subjectively) looks fairly good, and includes 4 fans as far as I can tell - but I wouldn't imagine airflow would be particularly great.
https://mdcomputers.in/circle-mid-tower-tempered-glass-eliminator-x1-red.html?sort=p.price&order=ASC
Within budget, I like the Spec_04 from Corsair. Only has a single 120mm fan included though.
https://mdcomputers.in/corsair-mid-...ass-cc-9011117-ww.html?sort=p.price&order=ASC
The Versa J24 is pretty nice IMO, but I don't believe it includes any fans... and it's currently out of stock...
A Case/cabinet is about 10% compatibility (does it fit your components) and 90% personal preference.
You have an ATX motherboard, so provided any case supports it, it's "fine".
Having a couple of pre-installed fans is a good starting point, and opting for one with a mesh front intake (opposed to solid/glass etc) would be a good choice too.
Hi Barty,
I am looking for a cabinet under budget. Most of the cases have front panel without mesh.
Is there any specific cabinet I can go under budget ?
If yes, please provide a link to it.
Thank you.
https://mdcomputers.in/thermaltake-...-ca-1l7-00m1wn-00.html?sort=p.price&order=ASC
I'm from India. It would be better if the cabinet comes under or equal to 6000 rupees.
Below are the websites I used. You can suggest me if you know other websites.
https://www.amazon.in
Here are my personal favourites
1.https://www.amazon.in/Cooler-Master...MI8_7ag-2Z4QIVkYqPCh1JSw-wEAQYBSABEgKxavD_BwE
2.https://www.amazon.in/Cooler-Master...MI8_7ag-2Z4QIVkYqPCh1JSw-wEAQYASABEgI2FfD_BwE
3.https://www.amazon.in/Cooler-Master...MI8_7ag-2Z4QIVkYqPCh1JSw-wEAQYBCABEgIPaPD_BwE
Now a quick advice for you.
Try to buy these locally from India, you can call the shops and tell them to courier you the cabinet.
Ifyou do some hardwork you may get these cabinets around 5000rs locally in India
Does not support the OP's chosen motherboard though.
https://www.msi.com/Motherboard/X470-GAMING-PLUS
I prefer this one, over the other as the front panel isn't 100% closed off.
3.https://www.amazon.in/Cooler-Master-MCB-B500D-KGNN-S00-MB500-Case/dp/B078BDMZ1Y?tag=googinhydr18418-21&tag=googinkenshoo-21&ascsubtag=k_EAIaIQobChMI8_7ag-2Z4QIVkYqPCh1JSw-wEAQYBCABEgIPaPD_BwE_k&gclid=EAIaIQobChMI8_7ag-2Z4QIVkYqPCh1JSw-wEAQYBCABEgIPaPD_BwE
My first priority is always a good performance. I am not interested in RGB. If there is a performance case without RGB I would definitely go for it. All I need is a good case with good air flow. Climate in my place is little hot. I don't want my processor to run into heating issues.
