Need Help on Pentium G3258 Overclock!
Billspear
79
I am new to PC and overclocking.
I manually overclocked my Pentium to 4.0GHz in my UEFI BIOS following an in-depth guide on overclocking on my Gigabyte GA-H81M-DS2V motherboard. My PC is booting up fine and is running well after Prime45 stress tests and my CPU temperature in RealTemp is NOT exceeding 60 degrees celcius on Intel's stock cooler. (Is that OK?)
However, in CPU-Z, it is showing my CPU Core Speed as 3192.38MHz (Stock speed). Why is this happening? Shouldn't it show 4000MHz? I'm concerned because my temps are almost twice as high as before even though it doesn't show my overclock in CPU-Z.
Edit: In my BIOS I:
-I changed the CPU PLL Selection to SBPLL
-I set the Uncore Ratio 100MHz lower than the Clock Ratio
-I set the Turbo Power Limit and Core Current Limit to around 120-150 each
-I set the CPU vRIN External to 1.800v
-I set the CPU vCore to Normal
-I set the CPU vCore Offset to +0.100v
-I changed the CPU Ring Voltage to Normal
-I set the CPU Ring Voltage Offset to +0.100v
Was any of this necessary to overclock to 4.0GHz? I will not go past this speed unless I get a CPU cooler.
- leave the CPU PLL to auto
- Set Uncore 300MHz lower as Core clock
- Leave the current limits on auto
- CPU VRIN is stock 1,800 thats ok
-Vcore on auto
- Dont use voltage offsets
Leave the Core multiplier Auto, change the Turbo multiplier instead
