Need help on R9 270
gowtham7000
37
Hi folks,
I have installed a graphics card in my system and found some abnormalities. Screen goes off for a second and turns back ON on its own. This happens rarely but it never happened before the graphics card. Clearly its due to Gcard but I couldn't figure out why it is happening. Please help me figure out.
Here is my spec,
GPU - Sapphire R9 270
CPU - i5 4570
Mobo - Gigabyte H97m D3H
PSU - Corsair VS650
RAM - Corsair Vengence 4GB x2
Monitor - Samsung 27inch
I have installed the driver cd that came along with the card.(AMD catalyst)
HDMI is used for connecting GPU & monitor.
The drivers coming with the CD might be outdated.
If you installed AMD Catalyst, make sure you have the auto-update and try to update your drivers manually.
If this is not a driver issue it might be a faulty HDMI cable / HDMI port (monitor or GPU).
Try another cable and another cable type if you can.
