Need help on whether purchasing these components are good and compatible
south_
Commendable
Jun 19, 2016
37
Hey guys! I am looking to upgrade my current computer to be able to play more modern games in with respectable fps and quality. Currently I have the following specs:
Windows 8.1 64 bit
a8 6500 apu
6144mb ram (probably ddr3 I do not know)
gtx 950 4gb
generic 286 watt PSU
asus K30bf_m32bf fm2 socket
HDD 149gb and HDD 763gb
Case is mATX
I want to focus on upgrading my HDD and CPU, so I searched and thought these were great:
Samsung 850 EVO 250GB 2.5" 6Gb/s Solid State Drive
GIGABYTE GA-78LMT-USB3 (rev. 6.0) AM3+ AMD 760G + SB710 USB 3.0 HDMI Micro ATX AMD Motherboard
AMD FX-8320 Vishera 8-Core 3.5 GHz (4.0 GHz Turbo) Socket AM3+ 125W FD8320FRHKBOX Desktop Processor
I currently have the budget of about $450. Should I try to purchase a PSU? Is there any other alternatives that are cheaper or better for the price? Is there any compatibility issues? I really need help as this is the first major PC upgrade. Thank you!
EDIT: By the way, my budget is $450 CAD.
DXDIAG
Okay guys this is what I can buy tomorrow at a nearby store. I chose not to include an SSD, however will buy one once I get more money. The CPU costs $155 CAD, so in total $429 including tax. How does this list look?
CPU: Intel Pentium G4600 3.6GHz Dual-Core OEM/Tray Processor
Motherboard: ASRock Fatal1ty B250M Performance Micro ATX LGA1151 Motherboard ($130.50 @ Vuugo)
Memory: GeIL EVO POTENZA 8GB (2 x 4GB) DDR4-2133 Memory ($79.99 @ Newegg Canada)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.98 @ NCIX)
Total: $260.47
Generated by PCPartPicker 2017-03-21 22:03 EDT-0400
Looks good, except that OEM chips don't come with stock coolers as they're meant for system manufacturers like Dell, HP, etc.
You'd have to buy a separate cooler if you get an OEM CPU.
I have a Cooler Master Hyper T2 that I plan to use as my CPU cooler. Hopefully that will work as it is currently working with my current motherboard at the moment. Is there anything I need to know about this upgrade though? I understand that I have to reinstall Windows 8.1 again by activating my key or something like that. I would also have to purchase thermal paste. I just want to make sure I make the upgrade correctly with messing up.
