need help overclocking (first time)
z0code0z
28
hello, this is my first time overclocking a cpu and i seriously dont know how to do it there is an amazing tutorial on how to do it with my fx 6300 but sadly my bios is so different that i dont even know what is should be looking for
could someone please just please help me overclock??
i would like to achieve a stable 4.3ghz with my fx 6300
my motherboard is a gigabyte 970a-ds3p
any help would be GREATLY appreciated,
thank you
Hi, I have the same CPU+MOBO. In the BIOS under M.I.T go to Advanced Frequency Settings ---> Advanced CPU Core Features ---> CPU Unlock and click Enable. Hope that helps :)
woah woah woah.......... thats all????????????????? i thought to overclock you needed to turn off things like cpu spread spectrum?? and a whole bunch of other things if its this simple then wowowowow 😀DDD also would it be a good idea to turn off things that are meant for power saving??? and also that thing that lowers what power the cpu takes, should i disable it???? also where could i change the cpu voltage??
thanks so much so far btw :)
