Need help overclocking i7 3770 (non-k)
cowboydude99
1,493
Hi all,
I recently install my new MB. ASRock Z77 Extreme 4 with my i7 3770 CPU. I'm cooling with Hyper 212.
I currently have my CPU @ 3.9GHz, by manually setting the multiplier at 39.
I am wondering how far I can push a non-k version. Is there anything I need to be aware of?
Its still a really powerful chip and I agree its not really worth the instability. For gaming you should still have no problem running a 290x when it comes out. I still run a first gen i7 950 @3.2ghz and it runs all my games without any issues. I got into overclocking and pushed it to 4ghz, but I brought it back to 3.2 as I didn't really need the overclock. Your CPU won't be limiting your GPU, its likely that overclocking the GPU will get you bigger performance games.
I would set the BCLK back...
I did. I set bclk = 100 and multiplier = 39.
This is fast enough for now, and my idle temps are CORE 1 = 31c, CORE 2 = 22c, CORE 3 26c, CORE 4 = 20c.
I do OC my 7970 to 1200mhz/1600mhz. I am just unhappy w/ the performance in some games like Tomb Raider and Skyrim (ENB).
Tombraider = Ultra, but SMAA = 2x, instead of 4x. I get around 35-40fps. If I turn SMAA to normal instead of ultra I average 45.
Skyrim with ENB = hitting like 40fps when Ambient Occlusion is turned on.
Try running a uningine valley benchmark with the extreme HD (highest) presetting and report the score
