tiny voices :
Yeah, 45 isn't possible. All computer temps are in C. That is normal. has nothing to do with Canada.
If your CPU is at 79, it is overheating. It should not leave the mid50s. You have a problem and that might be it. Make sure the cooler is properly seated.
I am using open hardware monitor.
Sensors
+- ASUS M5A78L-M LX PLUS (/mainboard)
| +- ITE IT8728F (/lpc/it8728f)
| | +- Voltage #1 : 1.428 1.08 1.428 (/lpc/it8728f/voltage/0)
| | +- Voltage #2 : 1.788 1.788 1.788 (/lpc/it8728f/voltage/1)
| | +- Voltage #3 : 1.908 1.824 1.92 (/lpc/it8728f/voltage/2)
| | +- Voltage #4 : 2.028 1.992 2.124 (/lpc/it8728f/voltage/3)
| | +- Voltage #5 : 2.028 2.016 2.028 (/lpc/it8728f/voltage/4)
| | +- Voltage #6 : 2.388 2.388 2.388 (/lpc/it8728f/voltage/5)
| | +- Voltage #7 : 0.6 0.6 0.6 (/lpc/it8728f/voltage/6)
| | +- Standby +3.3V : 1.584 1.584 1.584 (/lpc/it8728f/voltage/7)
| | +- VBat : 3.216 3.216 3.216 (/lpc/it8728f/voltage/8)
| | +- Temperature #1 : 40 40 40 (/lpc/it8728f/temperature/0)
| | +- Temperature #2 : 35 35 35 (/lpc/it8728f/temperature/1)
| | +- Fan #1 : 2109.38 2089.78 2109.38 (/lpc/it8728f/fan/0)
| | +- Fan #2 : 1138.28 1126.88 1140.2 (/lpc/it8728f/fan/1)
| | +- Fan Control #1 : (/lpc/it8728f/control/0)
| | +- Fan Control #2 : (/lpc/it8728f/control/1)
| | +- Fan Control #3 : (/lpc/it8728f/control/2)
+- AMD FX-4300 (/amdcpu/0)
| +- Bus Speed : 200.902 200.902 200.904 (/amdcpu/0/clock/0)
| +- CPU Core #1 : 3917.59 1406.31 4018.04 (/amdcpu/0/clock/1)
| +- CPU Core #2 : 3917.59 1406.31 4018.04 (/amdcpu/0/clock/2)
| +- CPU Core #3 : 1406.31 1406.31 3917.63 (/amdcpu/0/clock/3)
| +- CPU Core #4 : 3917.59 1406.31 3917.63 (/amdcpu/0/clock/4)
| +- Core #1 - #4 : 23.25 20.375 27.875 (/amdcpu/0/temperature/0)
| +- CPU Total : 10.1563 9.00298 38.4615 (/amdcpu/0/load/0)
| +- CPU Core #1 : 12.5 6.25 100 (/amdcpu/0/load/1)
| +- CPU Core #2 : 23.4375 0 31.25 (/amdcpu/0/load/2)
| +- CPU Core #3 : 0 0 45.3125 (/amdcpu/0/load/3)
| +- CPU Core #4 : 4.6875 1.5625 46.1538 (/amdcpu/0/load/4)
+- Generic Memory (/ram)
| +- Memory : 46.2172 46.2171 46.6332 (/ram/load/0)
| +- Used Memory : 1.84061 1.84061 1.85718 (/ram/data/0)
| +- Available Memory : 2.14192 2.12535 2.14192 (/ram/data/1)
+- AMD Radeon HD 6900 Series (/atigpu/0)
| +- GPU Core : 0.9 0.9 1 (/atigpu/0/voltage/0)
| +- GPU Core : 250 250 500 (/atigpu/0/clock/0)
| +- GPU Memory : 150 150 1250 (/atigpu/0/clock/1)
| +- GPU Core : 48.5 48.5 49 (/atigpu/0/temperature/0)
| +- GPU Core : 22 0 29 (/atigpu/0/load/0)
| +- GPU Fan : 27 27 27 (/atigpu/0/control/0)
+- WDC WD1600JS-22NCB1 (/hdd/0)
| +- Temperature : 36 36 36 (/hdd/0/temperature/0)
| +- Used Space : 57.7678 57.7678 57.7678 (/hdd/0/load/0)
Parameters
here is everything it's telling me.
also that was my GPU sorry.
