This is my first PC build, so initial apologies if I don't understand some terms.
I just finished building, when I power on my pc everything turns on; fans, cpu cooler, gpu cooler, leds (mobo and case). After 5-10 seconds everything powers down after a few seconds powers back on, this happens repeatedly. Nothing shows up on my monitor also (plugged a dvi-d to my gpu and my mobo).
Things I've done:
* Unplugged and replugged everything
* Checked thermals and gpu
* Checked every screw
* Left only 1 slot of ram in
* Tested my psu with a testing 24pin connector that comes with the psu
* Unplugged the gpu
PC Build: http://ca.pcpartpicker.com/list/99k6RG
At this point I'm fairly confident it's a problem with my mobo, not sure what else to do atm. I have 1 day left to get a rma with ncix. Should I get it tested with them or return it?
*When I did a test run before I put the mobo inside my case, the same thing occurred, I didn't think much of it at the time because everything turned on so I figured everything was working.
Things I've done:
* Unplugged the gpu
