Need Help Picking A Monitor
Genesis89
158
In my search for a 27 inch monitor mostly used for gaming ive found a few all of which people say default settings are really bad plus have ghosting. I find benq price to be the best but here is a list. Of course I'm only buying one, maybe a second later on. Thoughts?
Benq
http://www.amazon.com/BenQ-GW2760HS-27-inch-LED-lit-Monitor/dp/B00ITORMDC
Acer
http://www.amazon.com/Acer-H276HL-bmid-27-Inch-Widescreen/dp/B00G5AH2YG
Asus
http://www.amazon.com/gp/aw/d/B0099XBO5E/ref=cm_cr_mpr_bdcrb_top?ie=UTF8
Aoc
http://www.amazon.com/gp/aw/d/B00CMKOVPQ/ref=cm_cr_mpr_bdcrb_top?ie=UTF8
Yeah 1440p would look way better, it will lower the frame rates, but if you go for a 60hz monitor (which you should in my opinion), then the gtx 970 will handle it pretty well.
