Need help picking the right processor.
Amazing_Mr_potato
I'm building a gaming pc, im new to all the amd vs Intel stuff
My specs are gonna be a gtx 960 with 8 gigs of ram. Where as the processor is still a question. I need suggestions
I'll be using it to play all the high end games. I'll do some Sony Vegas and will do a live stream upload to twitch while playing some high graphics game. I'll also be using shadoplay to record my games.
What would you suggest?
My price range can go up to 200dollars. I can also increase the budget by a bit.
Suggest a good mother board to suit the processor you suggest. Thank you!
The best future proof cpu for the money would be a 5820k, if your willing to jump to x99, if you want be reasonable, get a i5 4460 and h97 mobo, will give great gaming performance for the next 3 years.
Being future proof is not really possible.
AMD gives you slightly Upper hand in Sony Vegas, but not that much
200 Dollar for only CPU or CPU+Mobo???
Build 01:
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($164.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.89 @ OutletPC)
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard ($82.98 @ Newegg)
Total: $272.86
Generated by PCPartPicker 2015-10-03 11:44 EDT-0400
Build 02:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($175.88 @ OutletPC)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($79.89 @ OutletPC)
Total: $255.77
Generated by PCPartPicker 2015-10-03 11:49 EDT-0400
I'm spending about 200 dollars just for the processor. I'll mostly play some high end game and record it with nvidia shadowplay or fraps. And I need the processor to be durable. I won't do any over clock
Intel Xeon E3-1231 V3 is Intel Core i7 4790 without Integrated GPU.
For Gaming: All of them perform same.
For Sony Vegas: Xeon 1231 > Fx 8350 > i5 4460
GTX 960 is not that much great for 1080p Gaming. R9 380 give you slightly better fps than 960. For true 1080p gaming you should go for R9 390 or GTX 970.
Build 01:
Total: $255.77
Generated by PCPartPicker 2015-10-03 12:03 EDT-0400
Build 02:
Total: $272.86
Build 03:
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($242.99 @ SuperBiiz)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard ($77.85 @ OutletPC)
Total: $320.84
Generated by PCPartPicker 2015-10-03 12:02 EDT-0400
Considering that I'll use shadow play while gaming to record the game( multitask) and the new direct x 12 what would be a better processor? An amd fx 8350 or an Intel i5 4460. I'll still be using Sony Vegas. I need a good durable build.
