APPROXIMATE PURCHASE DATE: at black friday
BUDGET RANGE:770$ for GPU only the 590 is a F dog only if it gets to 350 lol that would be epic
USAGE FROM MOST TO LEAST IMPORTANT:gaming wep surfing
CURRENT GPU AND POWER SUPPLY:8400 GS 500W (need new ones
OTHER RELEVANT SYSTEM SPECS: building new pc all info in bottom
PREFERRED WEBSITE(S) FOR PARTS:amazone
COUNTRY OF ORIGIN:KSA
PARTS PREFERENCES:Nvidia EVGA or msi
OVERCLOCKING:yes yaha yaha yahahahahahah ! the power the powa !
MONITOR RESOLUTION:IDK XD full HD 1080p 32 inch should be 1920x1200?
SLI:yah 2 way sli 570's iknow u will say go 2 way 560 ti but it isnt futer proof as i can go 3 way with the 570's
ADDITIONAL COMMENTS:need the gpu to be cold
info about build if needed
case HAF x
MOBO:asrock exetreme7 gen3 cheap and awesome
SSD 550MB (120GB)
HHD 1tb
some red led 200mm fan for top case
4x2 8gb ram vengance black low profile
core i5 2500k Over clooked to 4.5 -5.0Ghz
and srry for bad grammer
case HAF x
SSD 550MB (120GB)
HHD 1tb
