Need help regarding PSU and Graphic card
Aniket25
137
Guys my specs:
I5 2400
8gb ram
1tb seagate Hdd
I aM not using dvd rw...
M playing to buy HD7770. Or gtx 650 TI. Both required external Power connector..
M having Enter E-500W psu plzz Tell will thik psu can handel above mention any 1 Gfx card..
N i aM not having enough money to upgrade Both pus N gpu..
Here is link of psu that M having
http://www.amazon.in/gp/aw/d/B00H428Y9G
Thanks
Buying that PSU you are asking for trouble, never invest on cheap PSU or you will have problems later on, get one that it has an 80 plus certification, That PSU is not even a real 500w PSU. Get a Corsair, Coolermaster, Antec. Good luck!
i am already having that psu .. not having enough money to upgrade both PSU and Gpu..
is it possible to use that PSU..
Thanks And Regards
Bro currently i am using HD6450 2gb gfx card on that PSU .. that PSU also required 400w
i am using that GFX card past 2 yer ..
so is it possible to use gtx 650 ti or HD7770
Its a bad psu. It can do bad things. It can cost you a lot of money. If you want to take that risk you will be the one to suffer. I give my recommendations honestly because I want you to have a good pc that will last you a long time. Only you can make that final decision.
