Hello,
I am digging into a build for gaming.
I need a build around GeForce GTX 1070 DirectX 12 VCGGTX10708XGPB-OC 8GB 256-Bit GDDR5 PCI Express.
I have that. Looking in getting parts with in a month.
Budget: 500-600$ on everything to support the 1070. I have a mouse, keyboard and a monitor. I just need the PC.
System usage:
Gaming.
Do you need to buy OS: Yes / No
Please note that if you're using an OEM license of Windows, you will need a new one when buying a new motherboard.
Yes planning on buying windows 10. 90$ on amazon. Any cheaper options?
Preferred Website(s) for Parts: (e.g.: newegg.com, ncix.com -- to show us selection & pricing)
No preferred options. I do have many stores available around me. For example I have a microcenter i can reach for. (IL - Chicagoland/Westmont) to maybe help with purchase of a CPU and a MOBO combo. (For ex. I5-7600K with a z270 mother board are around 340-350$ combo)
Northwest Chicago/West suburbs, Illinois
Parts Preferences:
No preferences. I don't care if the CPU is intel or AMD. just want a good build.
Overclocking: Maybe? Not necessary.
Your Monitor Resolution: (e.g.: 1024x768, 1280x1024, 1440x900, 1600x1200, 1680x1050, 1920x1080, 1920x1200 or if you're upgrading please state what you'd want to get)
My monitor:
BenQ 27-Inch Gaming Monitor - LED 1080p HD Monitor - 1ms Response Time for Ultra Fast Console Gaming (RL2755HM) (Discontinued by Manufacturer)
Comments: (e.g.: Need to have a window and lots of bling, I would like a quiet PC.)
Don't need it to be flashy. But I do enjoy some open look in the case. The quieter the better for me and my space. If it's much better to go over my budget by 50-100 and it will give me a much better pc. But i don't mind going under also, of course
Thank you everyone before hand for any suggestions.
System usage:
Gaming.
Parts Preferences:
My monitor:
