Question Need help selecting RAM for x299x | 10980XE
Ouze
33
Hello all,
I am planning a 10980XE build. I have decided on the X299X Aorus Master motherboard. I've typically not felt really competent at picking the best RAM for builds, though - I don't really understand latency and such... so wanted to get some suggestions.
I'm not trying to do an extreme overclock - I want decent performance but stability is the most important thing for me. I want to do 64gb, and ideally, it will be not too tall - I am going to be cooling on air (Noctua NH-D15). I don't need RBG on them, and I'm not really building on a tight budget.
So, this is what I am looking at:
https://www.amazon.com/dp/B01N4MJL5K 64GB Corsair LPX (4x16GB) / Speed: 3600MHz / Tested Latency: 18-19-19-39 / Voltage: 1.35V
Is this optimal for my build?
Thank you!
