So I have had a Windows Update for a while that has been trying to be installed but always fail. Recently someone told me that is it because the Drive letters on my SSD and HDD are backwards. So I researched how to swap them. In a youtube video a guy does this quite simply. But he has three drives, and was able to put the page file on the third so that there was no problems changing/deleting the letters of the main two. But I only have two, so it is much more complicated. But I ran into a issue where I could not change SSD even though it does not have a page file.
Starting out I had:
-HDD - D, SSD - C and has boot and page file.
-Need them swapped. Can't change SSD because of page file.
-At this point I would delete HDD's letter so that D is available for SSD, but that has page file so can't. In order to change, need to move page. Only candidate is HDD, but the drive needs a letter in order to do so.
-Change HDD to H, so that D is not taken, and page file can be moved to it.
-HDD - H and has page, SSD - C and is still boot
-Tried to change SSD to D now that it is available and has no page, but does not work. "The parameter is incorrect." I was getting this earlier, but thought it was because the SSD had page file. But I am still getting it even though it no longer does.
-Changed HDD back to D because I had a major issue with Windows not being able to path find correctly with HDD being H, had to boot into Safe Mode to undo it.
So I'm now back to square one. Stuck because I don't know why I was unable to assign D to SSD even though it had no page file in it. I am suspecting it has something to do with the SSD being the boot? How do I swap the letters of two drives when all I have is those two drives?
Starting out I had:
