So I have been thinking about getting an SSD for a while, and it seems like prices now are pretty good. I have a few concerns about adding another drive to my desktop though.
First, will I be able to transfer over the OS without using a CD or key? A friend installed Windows 7 for me a while ago and I upgraded to Windows 10 alright from that, but he took all the CDs and such with him. Are HD cloning programs reliable to move over operating systems? (eg-Paragon Hard Disk Manager 12 or Acronis TrueImage) Which one is the best?
Second, I heard that most SSDs are 2.5" but my desktop is likely 3.5." From what I understand you can get a mount converter from 2.5 to 3.5" but is there any other compatibility issues I should be aware of?
Finally, when my roommate installed Win 7 (upgraded from Win XP), I partitioned my 500 GB HD. I thought I could simply shift-delete the old partition with the old OS along with it. It successfully deleted about half the files, but couldn't do the rest and now my computer is still dual boot but it gives me an error message and you have to hard reboot if you start up the XP partition. I've set the preferences to avoid that, but I was wondering if there was any way to completely remedy this problem if I switch over to an SSD.
Am I right in assuming if I use a HD cloning program that I can clone one partition and not the other, and then set the new SSD as the primary OS and then clear the entire old HD? How do I clear the old HD once I have the new one cloned? I learned the hard way I can't shift-delete, so I'd like not to make the same mistake twice.
Thanks for helping out the tech newbie.
