Need help to build PC for an architect
Aug 7, 2018
Hi guys! need your help to build a pc to work in 3dsmax, archicad, autocad, photoshop etc + to play pubg, civ, csgo etc
Currently we have
h81m-ds2
i7-4770 3.40
geforce gtx 660
16gb ram
128ssd
2tb hdd
All this since early 2014
The problem appeared from nowhere. Archicad files >200mb make the system think for minutes. However PUBG is running quite well. Decided to build a new PC.
The purpose is the same - to work in 3dsmax, archicad, autocad, photoshop etc + to play pubg, civ, csgo etc
Here is the possible configuration:
https://es.pcpartpicker.com/list/XNL84q
could you please check if it is good, or what should I change?
can it be cheaper?
do i really need 1080 now or 1070 is enough?
thank you!
You would do better to get a Quadro graphics card for the "work" computer. The drivers are optimized for CAD and OpenGL applications. Gaming cards like a 1080 are not optimized for your applications. Keep the old computer for gaming and build a purpose built work computer.
