need help to choose a motherboard
perez jens
267
hey,
i need help to choose a motherboard, cause i dont know that much from it.
these are my specs:
Intel Core i7 4770
2 x 4gb DDR3 RAM ( want to upgrade to 2 x 8gb )
Nvidia GeForce GTX 770
and i need to buy a new PSU to for the new GPU so u iff u could look that up to would be helpfull.
my budget for the motherboard is like 100€ - 150€
my budget for the PSU is like 100€ - 150€ ( minimum 600 watts and PCIe 6 and 6+2 or 8 )
i know its a bunch to look up but i dont know that much from it so..
i would appreciate iff u could look it up for me
thanks and grtz
,Jens
I definitely have to agree on the motherboard, you can either go with that one or a similar ASUS one:
http://www.amazon.co.uk/Z87-PRO-Motherboard-Express-Intel-Wi-Fi/dp/B00CXK57KS/ref=sr_1_4?ie=UTF8&qid=1388522085&sr=8-4&keywords=ASUS+Z87-A
As for your PSU, you have to think about if youre going to stick with one GPU or potentially do an SLI with a second card in the future. Because if youre thinking of one day adding a second GPU then youll need an 850W.
If that is the case then this would be a good PSU:
http://www.amazon.co.uk/Corsair-CP-9020056-UK-Series-Modular-Supply/dp/B00FG9FZS2/ref=sr_1_1?ie=UTF8&qid=1388522242&sr=8-1&keywords=Corsair+Professional+Series+Modular+HX850
Hope this helps!
The 750w will suffice for that, corsair is a really good brand but seasonic with it´s x line it´s at the top.
http://www.amazon.co.uk/Seasonic-X-750-module-ATX12V-Supply/dp/B002VAFDQS/ref=sr_1_1?ie=UTF8&qid=1388523520&sr=8-1&keywords=seasonic+x
