Need help to choose between M.2 or SATA 3 SSD
I have a dell inspiron 5567 with 1TB mechanical hdd. I am planning to install an ssd of 128GB and set it as boot drive.
Now as this laptop do not have M.2 slot, i have an option of using a M.2 caddy to install M.2 SSD in either optical drive slot or internal hdd area.
I need suggestions to choose between M.2 SSD ( like Samsung EVO 960/970) or a 2.5'' SSD ( like Samsung EVO 860). In either case, my selected drive will be used just for booting.
Keep in mind, I dont have a M.2 slot, i will use a M.2 caddy.
Thank you in advance
Jun 19, 2018
A normal SSD will not achieve the theoretical SATA 3 speed of ~750MB/sec, will a NVMe SSD achieve ~750MB/sec when plugged into SATA 3 port using an adopter, converter or caddy?
