Need help to choose new CPU
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hello, i got a LGA1155 motherboard with a I5-3350P Processor and i wunder if it will be worth to just buy new CPU for this motherboard or should i buy new motherboard + CPU? The motherboard is from a Acer Aspire x3995 Intel B75 Chipset.
Well if your running at 300fps then you drop to 180 you shouldn't care because you wont notice a difference unless you drop under 60 fps. Also if its only CS:GO that does it I wouldn't worry because it may just be CS.
The reason i do like a new CPU is becouse i play CSGO and i think the CPU is dragging me down on my FPS sometimes it drops but it might also be my GPU its only a Evga 750 Ti FTW & i recently bought a BenQ XL2411Z i do like to get constant 300FPS instead of 180-300 :)
So what is the reason that my FPS Drops alot? 🙁 i mean, you can just feel when you get a huge FPS drop on 100fps..
Since you have a higher resolution monitor, a graphics card upgrade is likely to make the biggest difference. Your CPU isn't doing any more work than it was before, but your graphics card is. Something like a R9 280X or GTX960 should give you the improvement you want.
Do you think my motherboard will handle a EVGA GeForce GTX 970 4GB? I mean, its not a gaming motherboard just a standard B75 chipset from Acer Aspire X3995 which i build over in a new case to get my GTX 750 TI FTW in? I do have a Coolmaster 600W PSU becouse it was on sale so i just bought this if i was in need of ugrade later on :)
