Need help to have a look at my mini-its build
cromnflexster
Commendable
Jun 21, 2016
4
CPU:
-Intel Core i5-6500 3.2GHz Quad-Core Processor
mobo:
-ASRock H170M-ITX/DL Mini ITX LGA1151 Motherboard
ram:
-Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory
storage:
-Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive
-Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
GPU:
-MSI GeForce GTX 750 Ti 2GB TWIN FROZR Video Card
PSU:
-Corsair CXM 650W 80+ Bronze Certified Semi-Modular ATX Power Supply
guys i need help checking out my build. I intend to build a mini-itx roughly about 700$ budget. please give opinion on my build esp the GPU
You don't need a twin fan GPU, you can get any EVGA GTX 950 they are all short cards and run fine as is. The extra fan is overkill on that card.
which gtx 950 should i go as my case will be quite compact in size and what about a GPU with twin fan
