Hello, i want to play online games but cannot seem to host the games. I can join others games but still it would be awesome if i could host myself as my internet speed is not that good. Anyway when searching i found i need to port forward to port no. 11155. I've tried to do it but i cannot seem to make it work. i used port trigger provided in my router but it just doesnt work. i am using windows 7. (cannot seem to add screenshots ..sry) anyway in port trigger option , i have multiple choices:
trigger protocol: UDP (??)
Open protocol: ??
start trigger port: ??
end trigger port: ??
start open port: ??
End open port: ??
these are quite confusing.. should i add 11155 in all these settings .
Also. i have other options in forwarding setting.. do i have to do it in sequential order..
1. DMZ configuration
2. Port Mapping configuration
3. Port Trigger configuration
(Edit: I also do have upnp setting, havent tried it yet but i heard only enabling it is enough will try today.)
Open protocol: ??
start open port: ??
End open port: ??
