Need help to see if all these computer parts go together.
MJ_Orozco
6
I'm trying to build a gaming pc for the first time and I looked at the parts that I want to get the problem is how will I know if these all go together. These are the parts and please tell me if im missing any parts.
Intel 7th Gen Intel Core Desktop Processor i7-7700K (BX80677I77700K)
Gigabyte LGA1151 Intel ATX DDR4 Motherboards GA-Z170X-GAMING 6
HyperX FURY Black 16GB Kit (2x8GB) 2133MHz DDR4 Non-ECC CL14 DIMM Desktop Memory (HX421C14FBK2/16)
Gigabyte GeForce GTX 1070 8 GB GDDR5 256 bit PCI-E 3.0 x 16 Windforce OC (GV-N1070WF2OC-8GD)
NZXT S340 Mid Tower Computer Case, White (CA-S340W-W1)
EVGA SuperNOVA 750 G2, 80+ GOLD 750W, Fully Modular, EVGA ECO Mode, 10 Year Warranty, Includes FREE Power On Self Tester Power Supply 220-G2-0750-XR
Seagate Expansion 1TB Portable External Hard Drive USB 3.0 (STEA1000400)
LowlySkeleton
235
I double what alexoiu says. There's always a note mentioning that the older chipsets might not work with Kaby Lake-S chips right out of the box if the board doesn't already have the bios updated for compatibility.
Otherwise, everything seems to be ok and compatible, though you should look into getting an aftermarket cooler for that 7700K. Here is how your build looks so far:
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor ($449.98 @ DirectCanada)
Motherboard: Gigabyte GA-Z170X-GAMING 6 ATX LGA1151 Motherboard ($223.50 @ Vuugo)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory ($154.99 @ Amazon Canada)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card ($524.50 @ Vuugo)
Case: NZXT S340 (White) ATX Mid Tower Case ($91.50 @ Vuugo)
Power Supply: EVGA SuperNOVA G2 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($139.99 @ Memory Express)
Total: $1584.46
Generated by PCPartPicker 2017-04-18 16:05 EDT-0400
Also, what do you intend to use this build for? Primarily gaming? Streaming+gaming? Video editing, etc? The 7700K is overkill if its ONLY gaming.
MJ_Orozco
6
I'm using this pc for streaming+gaming+video editing
LowlySkeleton
235
MJ_Orozco
6
