Need help updating to a newer video card
Wooket27
I am currently running a EVGA GTX 260. World of Warcraft runs ok but I have to turn everything down to fair/low. Would like to get something a little newer that would at least let me run higher settings.
mobo: Asus M3A78-EM
processor: AMD Asus(tm) 7750 processor 2.7 Ghz Dual Core
4G ram
650w PSU
Any suggestions?
Your dual core is what's holding you back in WoW, not the 260. Any new card you buy won't see any improvements in WoW because your CPU is limiting your system's performance
As with most MMOs, WoW is a fairly CPU intensive game
http://www.tomshardware.com/reviews/world-of-warcraft-cataclysm-directx-11-performance,2793-10.html
For WoW, powerful single threaded performance would be ideal, so an i3 or i5 + new mobo would be a great upgrade (fairly pricey too)
For your motherboard the Phenom II X4 965 should be compatible after a bios update (not really recommended but it's still an option)
http://pcpartpicker.com/part/amd-cpu-hdz965fbgmbox
BIOS update
BIOS update
If I want to upgrade the mobo and processor what would I need to look for with my current video card? I wanted to originally build a new machine and keep this one as well so my husband and I can both play wow.
So I now have a ASUS Crosshair IV mobo and a AMD Phenom II X4 965, same video card GTX 260 with current driver. My game is running worse. I had zero lag with the older mobo and processor. Now my I glitch all over the place. I have everything turned down to low/fair. Now what?
My PSU is a 600 I thought it was a 650.
Aside from this (he's usually right), be sure you have all bios updates for the mobo as well as any misc missing drivers. The simplest stupid driver missing can cause issues. Check your Device Manager for anything missing a driver.
