need help upgrading my GPU
Kaitlin Kaschak459
485
ok so i game on a 1920x1080p monitor and right now im playing doom 4 which runs like crap on my current setup heres my specs xeon w3565 which is the server version of an i7 960 stock speeds 16 gigs ddr3 ram and a 750 ti which i want to upgrade. i dont have a set budget yet any how heres a link to the power supply specs for my current psu
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01709672
no heres my gpu choices prefer to stick with Nvidia but am open to amd if the price to performace is good enouigh also must max out doom 4 on high and maintain a constant 60FPS on high
780 ti
980 ti
1060
first gen gtx titan
295X2
380
390
which card do you recommend would prefer to keep my current psu if possible because my psu is proprietary meaning it wired differently then an off the shelf psu
http://www.tomshardware.com/forum/285762-28-z400-requires-rewiring-system-board-power
1060 don't get complicated
question if i go with the cheaper 3gig 1060 would that hamper my doom 4 gameplay in terms of framrate and performace compaired to the 6 gig version?
also what is the difference if any between the regualer 1060 the turbo model and the super clocked
Kind of, not really though.
I recommend going for the 6GB version though, because it gives you 10% more performance and more VRAM to work with in those open world games that'll use a bit more.
The 3GB still performs a bit better than the RX 480, so either is a good choice.
Don't get the Turbo or SC models, stick with the Gigabyte Windforce cooler for entry level 1060 cards for each variant, they offer the best value cooling and performance.
The other two have poor cooling and acoustics.
any chance theres a low profile version because i dont think the 1060 will fit in my Z400 case as its the stock hp case
