[SOLVED] Need help using two audio inputs on a computer.
thefxgamingrules
192
35
4,640
Hi everyone!
So, what I require is rather basic: I attend piano classes on my PC. I use my microphone to speak to my instructor and use my microphone (Mic In {Pink input port}) and my mic also picks up (not very well however) what I'm playing along.
I'd like to use the audio out from my keyboard and plug it into the Line In (Blue Port) and have the audio inputted directly into the PC.
My question is however, how do I combine my mic's input and keyboard's input into a single virtual input device that I can select to use in say, skype or zoom?
Most likely you will need some sort of "mixer".
For example:
https://www.sweetwater.com/store/de...Vmo7ICh3zJQGjEAQYBCABEgKBqvD_BwE&gclsrc=aw.ds
However, that is only a generic suggestion and the details do indeed matter.
And here is a sort of tutorial to help:
https://www.musicrepo.com/record-keyboard-and-vocals/
What make and model keyboard and microphone are you using? What plugs and/or ports are available?
You can easily google for more information and modify the search criteria to meet your situation and requirements.
I am going to move your post from Apps and Software over to Home Audio. Very likely someone will be able to provide additional or even more direct suggestions.
For example:
Thanks mate
