Need help wall mounting an ASUS 31.5 in Monitor
Jun 1, 2018
I just bought a ASUS model VA325H 31.5 inch Monitor and I want to wall mount it but I only see two holes where a VESA mount would go. Has anyone come up with a way to wall mount this model?
The specifications for that monitor don't list support for VESA. They list the two mounting holes. My advice is to measure the distance between the two mounting holes (center to center). Then compare that to the VESA mounts. If they do not match up, then you can use a block of wood with two holes for the monitor and four holes for the VESA mount.
Note *with two convenient holes for mounting devices
https://www.asus.com/us/Monitors/VA325H/specifications/
The monitor weighs 15.1 pounds. So, a piece of 1 x 4 or 1 x6 should be adequate for the adapter. Or if you prefer, you can get a piece of Aluminum or steel to fabricate your adapter. Then paint it to match the monitor.
I haven't seen a commercial adapter for this , but it is a possibility.
