T TheLockstah Reputable Mar 17, 2015 37 0 4,540 Mar 23, 2015 #1 Hey so I'd like some ideas on a case and PSU to pick, I'm on a budget build and I'll be running a i5 4690K on a Gigabyta Z97-D3H board with a Sapphire Vapor X 280x
Solution logainofhades Mar 24, 2015 No need to spend that much, you can get a solid system, with OS, monitor, keyboard, and speakers for a little over 1.5k. PCPartPicker part list / Price breakdown by merchant CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($227.99 @ SuperBiiz) CPU Cooler: Zalman CNPS10X OPTIMA CPU Cooler ($25.99 @ SuperBiiz) Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard ($139.99 @ SuperBiiz) Memory: Mushkin Silverline 8GB (2 x 4GB) DDR3-1600 Memory ($54.99 @ Newegg) Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($114.99 @ Newegg) Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive ($65.29 @...
procollision Reputable Mar 4, 2015 75 0 4,660 Mar 23, 2015 #2 what is your budget? you should probably look at tier 1 or 2 in this list (around 500 w) http://www.tomshardware.co.uk/forum/id-1804779/power-supply-unit-tier-list.html Upvote 0 Downvote
T TheLockstah Reputable Mar 17, 2015 37 0 4,540 Mar 23, 2015 #3 procollision : what is your budget? you should probably look at tier 1 or 2 in this list (around 500 w) http://www.tomshardware.co.uk/forum/id-1804779/power-supply-unit-tier-list.html My budget is $2000, but that's also including my new peripherals which is about $200 Upvote 0 Downvote
logainofhades Titan Moderator Apr 27, 2009 37,559 3,223 143,290 Mar 23, 2015 #4 $2k is a budget build? You can do far better than that, for $2k, even with peripherals. Upvote 0 Downvote
T TheLockstah Reputable Mar 17, 2015 37 0 4,540 Mar 23, 2015 #5 logainofhades : $2k is a budget build? You can do far better than that, for $2k, even with peripherals. I'll only spend that much if I actually have to, I'm trying to keep the price down as much as possible Upvote 0 Downvote
T TheLockstah Reputable Mar 17, 2015 37 0 4,540 Mar 23, 2015 #6 logainofhades : $2k is a budget build? You can do far better than that, for $2k, even with peripherals. I'll only spend that much if I actually have to, I'm trying to keep the price down as much as possible Upvote 0 Downvote
logainofhades Titan Moderator Apr 27, 2009 37,559 3,223 143,290 Mar 24, 2015 Solution #7 No need to spend that much, you can get a solid system, with OS, monitor, keyboard, and speakers for a little over 1.5k. PCPartPicker part list / Price breakdown by merchant CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($227.99 @ SuperBiiz) CPU Cooler: Zalman CNPS10X OPTIMA CPU Cooler ($25.99 @ SuperBiiz) Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard ($139.99 @ SuperBiiz) Memory: Mushkin Silverline 8GB (2 x 4GB) DDR3-1600 Memory ($54.99 @ Newegg) Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($114.99 @ Newegg) Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive ($65.29 @ Amazon) Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card ($332.99 @ Amazon) Case: Corsair SPEC-03 Red ATX Mid Tower Case ($59.99 @ Newegg) Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($77.25 @ Mwave) Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.99 @ NCIX US) Monitor: Asus VG248QE 144Hz 24.0" Monitor ($264.99 @ B&H) Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($27.87 @ Amazon) Speakers: Logitech Z313 25W 2.1ch Speakers ($33.89 @ SuperBiiz) Total: $1516.21 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2015-03-24 11:22 EDT-0400 Upvote 0 Downvote Solution
