Building a new pc; I'm new to this... need help with a motherboard; here's are the components that I will go with :
I5 - 6600k or i7 4790k (for gaming and some design, nothing heavy)
cooler master hyper evo 212
corsair vengeance LPX 8gb (2x4gb) DDR4-3000 memory
WD black FZEX 2tb 7200 rpm
gigabyte gtx 970 G1 or MSI 980 (depending on the budget, will use it at 1080p)
NZXT S340 ( would the G1 fit comfortably in here ?)
EVGA Super Nova G2 550W 80+
Motherboard I had this in mind http://www.newegg.com/Product/Product.aspx?Item=N82E16813128846&cm_re=z170-_-13-128-846-_-Product. What suggestions do you have ?
BoNuS round question : what do you think about the build; does everything go well together ?
