I am starting a new build and have a few questions. The case I am thinking about using is the Fractal Design Meshify C, the Corsair Hydro Series H100i v2 mounted up top and the EVGA GeForce GTX 1080 Ti SC Black Edition GAMING GPU. Now with the H100i v2 up top, it says the max motherboard component height is 40mm but the ram I have (already purchased) is listed as 44mm. So if my math is correct, they will not fit together. If I mount the H100i V2 on the front, which I prefer not to do, the GPU may be to long for the cases max GPU length of 315mm.
So, should I change the case? What would be another good airflow/low temp case that would work? Could I just switch from a liquid cooler to an air cooler, and what would be the best option for an air cooler that would fit, like the Noctua NH-D14, which this site lists ast the best air cooler.? If the H100i v2 mounted up front would fit with the GPU, would the radiator restrict the air flow into the case enough to drastically raise the temperatures.
thank you
the parts
https://pcpartpicker.com/product/Y6Crxr/fractal-design-meshify-c-atx-mid-tower-case-fd-ca-mesh-c-bko-tg
https://pcpartpicker.com/product/McH48d/gskill-trident-z-16gb-2-x-8gb-ddr3-3200-memory-f4-3200c14d-16gtzkw
https://pcpartpicker.com/product/CrDzK8/corsair-cpu-cooler-cw9060025ww
https://pcpartpicker.com/product/gwJkcf/evga-geforce-gtx-1080-ti-11gb-sc-black-edition-video-card-11g-p4-6393-kr
thank you
the parts
