Need help with a self-build computer I want to make !
Dec 17, 2013
44
Hello Tom's Hardware users.
I'm currently saving up for a gaming computer I want to build.
These are the current specs that I want to buy;
CPU: AMD Athlon II X4 760K Black Edition Boxed
Motherboard: ASRock FM2A75M-DGS
Graphics Card: MSI GeForce GTX 770 Twin Frozr Gaming 2GB OC
Hard Drive: Samsung SpinPoint M8 HN-M500MBB, 500GB
Monitor: Acer G226HQLBD Black
RAM: G.Skill RipjawsX F3-14900CL10S-8GBXL ( 2x4GB )
Optical Drive: Samsung SH-224BB Black
Power Supply: Corsair CX750M ( 750W )
The total price should be € 704,35 ( Euro's )
Is there anything that could have been better or something that need's to be changed ?
If so please tell me because this will be my first gaming computer.
Regards,
420
Your cpu will bottle neck that gpu. Get a fx6300
Also that mobo is fm2 not am3/3+ to even support that cpu. You want an am3+ board preferably 990fx or 970 minimum
Actually i think that cpu is am2+ that you chose. Its pretty outdated
Besides that your gpu and cpu are good. I would suggest a cpu heatsink as well like the hyper 212 which is cheap. The stock coolers arent very good
actually that's an A class APU with the display removed and it's FM2. it's correct.
i was just as surprised when i first heard about them. it's a fx4300 series basically since the apu uses the same piledriver modules. but without the l3 cache and on fm2 instead.
still a fx6300 and am3+ board is a better choice.
I see I will choose the Asus Sabertooth 990FX.
And any good cases for around the 100-130 Euro's that can hold about a fair amount of fans and isolates noise good, are you guys familiar with that?
If not I will ask around further. Already been helpful enough :)
