Need help with a tricky repair
Savvy_01
113
The specs: Laptop
Acer Aspire 5534
AMD Anthlon 64 X2 Processor
ATI Radeon HD3200
15.6" 16:9 HD LCD
4 GB RAM
320 GB HDD
DVD Super-Multi DL Drive
Acer Nplify 802.11/b/g/Draft-N
6-Cell Li-ion Battery
Windows 7 Professional, SP 1 (It was fully updated before repairs began, hasn't been updated yet since the problem persists regardless of Service pack.)
The Problem: It present itself as a malfunctioning keyboard and touchpad lock button. Specifically, the touchpad locks on its on after a few minutes and refuses to unlock, forcing the use of another external mouse. Specific keys on the keyboard don't work, and won't register a key press (Always the same keys too, s, g, h, \, left-shift, and the . on the keypad.). Other keyboards plugged in work fine.
Solutions Attempted before the laptop came to me: A reinstall of windows, which gave me the go ahead for any additional wipes or modifications.
Solutions and diagnosis I've come up with:
Outdated/Corrupt Drivers: Using Device Manager to Update Drivers (Already updated). Downloaded Acer Aspire 5534 Keyboard drivers and no change in the issue.
Virus: Ran Hiren's Boot CD and found a trojan Crypt-426 on the keybtray.exe process using Clamwin. The keybtray.exe process is only on the X:/ drive which is reserved for booting off of CDs or USBs (HBCD and the Windows Installer used it.) No other virus removal program detected it (AVG and Malwarebytes used). Final Solution attempted was to wipe the drive entirely (System Partition included) using DiskPart in the command prompt while using the Mini-XP OS booted off the HBCD. Assumed that the virus was a false positive. No change in the issue.
Partition Table: Startup repair detected errors in the partition repair, but failed to repair the issue after 5 attempts. Diagnosed the computer with hard drive failure and installed alternate drive (new). After reinstalling windows, problem persists anyways.
Hardware failure: Dismissed because the keyboard and touch pad work perfectly in Mini-Xp and Ubuntu. If it was hardware, it would consistently malfunction regardless of what OS was being used.
Software Failure: Dismissed after repeated reinstallations and a new hard drive was installed. (500 GB Hard drive to be specific).
RamDisk containing a virus: Noticed a RamDrive when initially using Mini-xp but dismissed it as nothing, but considered that the virus could be hiding there. Removed RAM for a few seconds and reinstalled. No change in issue.
Evil Spirit: Blessed the computer with Garlic Bread and Sunlight. No Change in issue.
Ran GMER and returned this error:
---- Kernel code sections - GMER 1.0.15 ----
? \I386\SYSTEM32\NTKRNLMP.EXE kernel module suspicious modification
? \I386\SYSTEM32\NTKRNLMP.EXE The system cannot find the file specified. !
Unsure of how to proceed with these errors, and they persisted throughout each installation and both hard drives.
As you can see, I was very thorough in listing everything that has occurred. Since I've ruled out hardware or software, I'm at a complete loss so listed literally everything I could think of. The only thing that I'm lost at is the Kernel errors, or why they persisted along with the problem. It's possible that they are related, but anything that survives a new hard drive is beyond my knowledge.
Also scan with Malwarebytes Anti-Malware and a Antirootkit... AVG has a Freeware antirootkit, as well as other developers and some antivirus scan also scan for the type of bug. And if you don't have to restore the system disable System Restore because some bugs can hide in the restore points folders where they are not easy to detect or can restore themselves from there if they were to be caught and deleted.
