Need help with an hometheater PC, just checking whether it's gonna be fine or not.
zNsherlock1
Commendable
Mar 21, 2016
Hi there, I was wondering whether the following pc would run an hometheater pc, it's basically just gonna play some youtube, popcorn and some netflix. Intel Celeron 1037U 1.8GHZ CPU 4GB OF DDR3L 128GB SSD It's a Brix from Gigabyte.
Thanks a bunch in advnace
Hi, thanks a bunch for your answer and help.
Do you think any of the following cpus would be better?
3205U
N3000
N3150
N3050
Again, thank's a lot.
Yeah I would defo go for an I3 if I was able to, sadly I'm limited to the options I mentioned above.
What do you think would be the best buy out of all these cpus?
Thanks!
They'll all serve the purpose, it's just the poorer graphics quality. Should be fine, as I said at 720 or 1080p, but you'll never know 100% until you can try it out.
Out of the options available the N3150 is the only quad-core, and they all have 8th gen graphics.
For the quad-core reason, I'd suggest the N3150 if your options are limited to those.
