What is your budget? 60hz is fine I doubt you will exceed 60fps no matter your system with armas terribly unoptimized engine, if you play games other than arma I would look at 120hz or higher panels. A TN panel is more responsive than IPS, I would recommend a TN if you are really into twitch first person shooters, but in arma I would probably prefer the accurate and vivid colors of an IPS over the better response time of a TN. As for resolution 1440p would be nice, maybe 4k although i'm not sure how well arma will run at 4k, I would think it would be fine with your i7 and gtx 1080 system but like I said the engine in that game is not exactly what I would call optimized.
