[SOLVED] Need help with ASRock B450 Pro 4
Nov 9, 2021
ok so i want to see if this is capable of using 2 3060 TIs on their peak? and if it can work like that, and if its a good pick for that?
or if not, whats the best and cheapest motherboard with 2 pci-e x16 slots that can support 2 3060 TIs?
Are you going to tax the system with mining? Might want to read through this then. If it's for gaming, don't bother, it's not support for the RTX3060Ti's. Also, the motherboard does not support SLI but it does support CrossFireX.
hey thanks for the answer, i mean yes i wanted to mine with it, and i have done the profitablity for myself and i find it fine for me, since 3060s are pretty cheap in my country too for some reason, but anyways, if i want to use 2 3060s in a motherboard, it needs to support SLI then, right?
