[SOLVED] Need help with best $2000/high end gaming PC parts list
Zombie_hunter99
Commendable
Mar 8, 2016
69
Hi Everyone, I need someone to help me build a parts list. My budget is about 2000 dollars. I was planning on getting a GTX 1080 TI, but I don't know what model to get and what brand. I was deciding between an Intel i7 9700K or i9 9900K. Which one is better for gaming? Should a get a AMD Ryzen processor instead or go with Intel? Also, I want to have a motherboard that has drivers for Windows 7 and Windows 8,1 because I prefer Windows 7 and Windows 8.1 over Windows 10. I don't know what type, brand or model to get that would be compatible with my processor of choice and Windows 7 or Windows 8.1. For this build I want a 2 TB m.2 or NVME SSD. I need 16 GB of DDR4 Ram. I plant on using this computer for playing video games, recording and maybe streaming my game play, watching videos, playing music, doing schoolwork, browsing the internet, and doing some video editing. I want to be able to run all of the latest and past games in 1080P and a solid 60 FPS at the max graphics settings. I plan on getting a 144 HZ or 4K monitor and maybe even a VR headset in the future and I want to be ready. Thank you, hope you can help me and happy holidays.
Why do I get the feeling that the final partlist is gonna have a maximus mobo, gtx 1080 class gpu and a 9900k ( cuz obviously the op would upgrade to that with the remaining cash)?
It's the partlist I suggested in the first place XD.
But in case you feel that you want a stronger gpu :
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor ($369.89 @ Amazon)
CPU Cooler: Cooler Master - MasterLiquid ML240R RGB 66.7 CFM Liquid CPU Cooler ($99.99 @ Newegg)
Motherboard: NZXT - N7-Z37XT-B1 ATX LGA1151 Motherboard ($149.99 @ NZXT)
Memory: G.Skill - Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory ($234.99 @...
4k 60hz monitors are the ones mortal, normal ppl can buy. 4k 144hz screens start at 2000 usd. So I think it's safe to say that it's out of the question.
For a 60hz screen, it's enough if your cpu can give 60fps in a game engine which the ryzen can. But ryzen has 8c/16t in its 2700X for half the cost of the 9900k. Now do you get why ryzen is a win win in 4k?
The X470 is also about 50 bucks cheaper than the maximus hero. So that 300 bucks can go for a better gpu for 4k.
Ppl already discussed about mobo vrm, cooling, overclocking capabilities of the mobo with a 9900k in this thread. Read the replies again to understand them.
The coolermaster ml360R aio I suggested is one of the best performing aio now. Enough to cool the 9900k.
Also when it comes to gpu's youre between a rock & a hard place , do you take a 1070ti at $400 ,step up another $100 for a 1080 or 2070 for around 15% more performance , or double the price for a 1080ti or rtx 2080 for around 40% more improvement - arguably worth it if you want to run 4k in the near future??
Unfortunately nvidia have the market sewn up in the higher end segment & only the 1070ti & 1080/2070 are reasonable value at present.
The only REAL 4k card is the 2080ti which is well over $1000.
Whats wrong with updating the bios on that motherboard? That will be very easy to do and should only take a few minutes.
I am more interested in running 144 hz than 4k. The 1080 TI's that I looked at were over 1000 dollars.I don't want to spend that much on a graphics card. I think the 1080 will suffice because I can get one for around the same price as a 1070 TI and the performance is pretty close to that of a 1080 TI.
Already been said, the thermals & power draw on these new chips are huge compared to what intel pushed out in the past.
For anything past a locked intel 6 core cpu you absolutely NEED a quality board with a good vrm setup & a very good cooler.
Something like
CPU: Intel - Core i7-9700K 3.6 GHz 8-Core Processor ($409.99 @ Amazon)
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler ($89.90 @ Amazon)
Motherboard: MSI - MPG Z390 GAMING PRO CARBON ATX LGA1151 Motherboard ($179.99 @ Amazon)
Total: $679.88
Generated by PCPartPicker 2018-12-20 04:28 EST-0500
S
What is VRM?
According to this link https://www.asus.com/us/Motherboards/PRIME-H310M-E/HelpDesk_CPU/
That motherboard is compatible with that the i7 9700K. It is listed in the CPU Compatibility table.
if it ships with the 0803 version of the BIOS yeah... it should work... how you gonna check that?
needs bios updating,poor vrm setup,3+1 phase no heatsinks, m2 nvme limited to 2x speeds.
Absolutely awful choice of board for anything past an i5 8400 & has no place at all in a high end $2000 build.
What happens if the board has a bad VRM setup? How would that affect the processor? Where did you see the board was limited to to 2x speeds for the M.2/NVME?
What is a CPU cooler that you would recommend for the i7 9700K?
I'm picturing MadMatts avatar, if you insist on getting a cheap motherboard. Do not come here complaining about it not posting, instability and BSODS.
Take some advice into serious consideration, as some of us put effort into guiding you. And Matt usually is quite spot on.
Black OPS IIII will take a gtx 1080 at least to push 1080p 144hz very high detail. Games make use of hyper-threading and so will your video editing software. You're likely going to run into complications, where you'll find the need to reinstall windows anyways. It's better to reinstall with the latest operating system to ensure you're running optimally on a "clean slate". If performance is what you're after wouldn't you want the piece off mind knowing there isn't any hardware/driver remnants (tied to your previous hardware) still on your hard drive, that could cause performance/stability issues?
