need help with build
TheCrazyStoner420
7
ok the build im trying to do is with a i5 4690k. Msi gtx 980, and corsair 760t or fractal design r5 if you can help me pick out other parts. Im trying to keep it between 1000 to 1500.
Any help would be appreciated thank you
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($199.99 @ Micro Center)
CPU Cooler: Noctua NH-U9B SE2 37.9 CFM CPU Cooler ($44.98 @ OutletPC)
Motherboard: Asus Maximus VI Hero ATX LGA1150 Motherboard ($131.24 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($72.88 @ OutletPC)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($99.99 @ Micro Center)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($43.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card ($544.99 @ SuperBiiz)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($99.99 @ Amazon)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($14.99 @ SuperBiiz)
Total: $1353.03
Generated by PCPartPicker 2015-02-10 21:24 EST-0500
Fan I would suggest the corsair sp120 or sp140 if ur case can support the 140mm fans. For the front STATIC PRESSURE=SP use static pressure for things like the front of ur case where it had to push air through the hdd cage or on a cpu cooler where it has to push through something. If there is nothing in the way of the fan get a AIR Flow fan
