Question Need Help With Build
Mar 12, 2019
18
4
25
I need help with a build. I started one, but I don't think its good enough. I would like to be able to play games (like Rust, Fortnite, PubG, etc.)as well as do school work with no lag. I want a new keyboard, mouse, and monitor. My budget is $1000, however I can go over by a little if needed.
Summary:
Games: Able
Work: Able
Keyboard: Want
Mouse: Want
Monitor: Want
Budget: $1000
https://pcpartpicker.com/user/Mshuto1/saved/DHQFt6
Reactions: Banned by Net
The build look pretty good but on the nzxt website, you can see how much fps some of those games you want to play run at.
School work should not be a problem with that not taking up even a little of the computer power.
Good luck with the building!
