Need help with building a new rig
Xryuh
13
Hey guys, I've never built a gaming computer before and I really need some help so if you can, thanks.
Approximate Purchase Date: Sometime this week or next week
Budget Range: 3000$ I can go a little higher if needed
Uses: I'll be using it for gaming, watching movies, video editing and rendering
Are you buying a monitor: Yes just 1
Parts Preferences: Intel
Overclocking: Yes
SLI or Crossfire: Maybe
Your Monitor Resolution: I would like what ever would be the best
Additional Comments: I also need a mouse and keyboard
Avenged7x
109
What games are you planning to play? And at what resolution? seems your talking single monitor so is that 1080p or do you want to spend around $600 for a 1440p monitor?
Do you need to buy an OS?
Location?
For $3000 you can build a serious system, but if your just gaming at 1080p you can build a very strong system for 1/2 of that.
Xryuh
13
First off thanks :), second I'll be playing Leauge, BF3, Fary Cry 3, Skyrim, Fallout stuff like that maybe a few MMOs. Yeah get me a 1440p monitor please. Yes I do need a OS and I live in North Carolina.
sharkbyte5150
901
Add a keyboard and mouse of your choice to this and you'll be in great shape.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=22061786
Notes:
The Zalman CPU cooler is what I use and I love it, works great and looks awesome but the Hyper 212 EVO is very popular, does a great job with OC'ing.
I built this list a while back as an all-purpose gaming desktop that can handle just about anything. It's very similar to the system I built that I'm using, just better graphics and more geared towards gaming and OC'ing compared to mine. Coming in at $1880, plenty of room for any upgrades or other parts you might want.
Avenged7x
109
Try this. Unlocked i7 with 16gb of LP ram for your video editing needs. I went with a good bang for buck air cooler if you want to push higher OC go with the Noctua NH-D14. For secondary storage you can choose the lower power and cheaper WD Green, I like the 5 year warranty of the WD Black. I generally prefer nVidia but at 1440p I think the extra VRAM of the 7970 will be beneficial especially if your going to run a bunch of Skyrim addons. That being said a 4GB 680 would fit into your budget or even a 690. Case is personal preference, the PSU is modular and leaves you headroom should you decide to run dual GPUs in the future. You can choose your own mouse/keyboard.
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($229.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Newegg)
Motherboard: Gigabyte GA-Z77X-UD3H ATX LGA1155 Motherboard ($144.99 @ Newegg)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1600 Memory ($89.98 @ Outlet PC)
Storage: Western Digital Caviar Black 2TB 3.5" 7200RPM Internal Hard Drive ($157.99 @ Adorama)
Storage: Samsung 830 Series 256GB 2.5" Solid State Disk ($159.99 @ Newegg)
Video Card: Sapphire Radeon HD 7970 3GB Video Card ($392.98 @ Newegg)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($129.99 @ Microcenter)
Power Supply: SeaSonic M12II 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($99.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($17.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Monitor: Asus PB278Q 27.0" Monitor ($649.98 @ Amazon)
Total: $2193.84 (Prices include shipping, taxes, and discounts when available.) (Generated by PCPartPicker 2013-03-06 15:30 EST-0500)
