Hello friends ,few months back i asked about if i should purchase certain graphic card and after that i realized that there is no point in trying to upgrade my current PC since its SO old.
So if anyone has few mins. to spare and help out with this PC thank you in advance
This PC is by no means High End PC ,but with what i have in mind it will be at least 5 times better 😀
I decided to do this now because i need to git gud on Dark Souls 1 since Dark Souls 3 is coming out in April.My PC is so old that it can't even run DS1 with more then 30 FPS with DS fix.I am faaaar from min. req. to play DS3
So here is what I had in mind:
CPU:i5-4690k or i5-6600 Skylake now i didn't understand which CPU is better so yea 😀
HDD:I plan to buy SSD SATA3 120GB Kingston,and use my old HDD for storage.Now i don't know if that can affect PC speed but better safe than sorry.HDD is 1TB Seagate on 5900 RPM
RAM:HyperX Fury 8GB DDR4 2133MHz
Graphic Card: GTX-960
Motherboard:Gigabyte GA-B150-HD3P
Power Supply:I really don't understand anything about it so i don't know which one should i use with this PC
Case:Same thing as power supply ,i only found this one that is in my price range- Zalman Z11 Plus
So thank you in advance for all the help
TumeX
P.S: If you maybe think that some part is better then the one that i listed and is just a bit more expensive ,feel free to say so
