Need help with cabling, especially the front panel header.
south_
Commendable
Jun 19, 2016
37
Asrock b250m HDV
CX 500 Corsair 500w
I am at the point after I have inserted the 24 and the 4 pin.
Now I am lost trying to insert the proper cabling.
I have tried to modify the casing of the connector to insert the system panel header. I have made it so the black wire is powerled negative and red wire powerled postive. However, there is still a white and a green wire that i do not know wat is it for.
Also I have a bunch of other wires and need to connect my SSD and HDD I am confused with.
Thank you
EDITED: My case https://www.asus.com/ca-en/Tower-PCs/M32BF/
It doesnt tell me the model or whatever. The power button has all of the 4 wires connected to it. Red, black, white, green.
alrigh so the pc does turn on and if i hold the power button it turns off. LED works too. however, when i turn it on there is no display or anything. wat do i do?
g4600 intel pentium
gtx 950
i tried connecting my display to both the video card to the mb but still nothing
display still doesnt work
i double checked and everything should be connected. my monitory was working yesterday night so i dont think its the monitor.
im thinking about just taking apart everything out. i mean is there a compatibility issue? everything seems fine in the pc picker list.
should i redo everything?
Asrock b250m HDV
CX 500 Corsair 500w
intel pentium g4600
gtx 950
samsung evo 850 250 gb ssd
generic HDD 1 tb
generic dvd drive
There maybe something you missed, or like you said the monitor may not work. Try another monitor
Buy a speaker. If it beeps more than 1 beep there's a prob somewhere
That screw hole in the pics you posted. Above CHA_FAN2. Doesnt look like it's got a standoff behind it
Did you put the standoffs in the case before you installed the mobo
If you didnt the back of the mobo will short on the case
the case is made so that there is space between the mobo and the case so yea there are standoffs. will any speakers work? will try one i have right now. i have re sockted the cpu the heatsink and made sure everything is inserted properly. Ill post a picutre of wat i have without the video card. maybe i am doing something wrong. forgive me for the cable management i honestly dont care about air flow i just want it to work.
http://imgur.com/a/8fA0c
