Need help with Case and Power Supply
jdbceltics
37
I am building a gaming rig soon and need to know 2 very important things.
1. Is a 750W Power Supply good enough for GTX 460 1GB SLI and an Intel Core i7 950? If not, what IS enough. Any links or specific power supplies would also be greatly appreciaged.
2. Is a mid-tower case big enough for GTX 460 1GB's in SLI? By big enough, I mean actual size (i.e. will the components fit) and heat (specifically, will the small size limit airflow). The specific case I am wondering about is the NZXT Nemesis Elite--->http://www.newegg.com/Product/Product.aspx?Item=N82E16811146030
If this case will be good for SLI and cooling, than I will be happy with it. If not, can any of you reccomend a case that can? It must be no greater than ~$150, and a side panel window is almost a must have (for me).
So in advance, thank you all for your help, I do appreciate this, as I might screw up if I do it all by myself.
---JB
