L Lil_boke Jun 10, 2019 5 0 10 Jun 10, 2019 #1 I chipped a corner piece of a 2gb ram stick is this ok to use is it safe.
R_1 Expert Ambassador Sep 8, 2015 8,440 632 49,290 Jun 10, 2019 #2 the flberglass substrate? if no traces have been severed it should be ok. a chip in a memory chip? I would not try it. Upvote 0 Downvote
NightHawkRMX Titan Ambassador Jan 1, 2018 18,639 4,007 81,540 Jun 10, 2019 #3 If the chip is near the corner of the stick, when you turn on your pc, worst case is your pc doesnt turn on. Upvote 0 Downvote
L Lil_boke Jun 10, 2019 5 0 10 Jun 10, 2019 #4 The ram does work I just want to make sure it’s safe the chip is on the bottom left corner and it’s mostly just the blue cover that came off but there is a very thin layer of the fiberglass that came off. Upvote 0 Downvote
NightHawkRMX Titan Ambassador Jan 1, 2018 18,639 4,007 81,540 Jun 10, 2019 #5 Should be ok. Upvote 0 Downvote
L Lil_boke Jun 10, 2019 5 0 10 Jun 10, 2019 #6 remixislandmusic said: Should be ok. Click to expand... Ok thanks Upvote 0 Downvote
