Need help with compatibility
May 13, 2018
37
Hi, I currently have the i5-6500 and my motherboard is the asus h110m-c. I want to upgrade my processor to the i7-7700k. Is this compatible with my motherboard?
it will work with bios 3016 but you will need much more cooling than the cooler that came with the i5-6500.
don't upgrade to the 7700k on that main board the K chips are meant for OC your main board is not go with a non K chip like the i7-7700.
i have a different bios than what it needs, but should i update my bios rn? and if i update my bios rn, will it ruin the function of the cpu atm?
so does that mean they are not compatible?
it will work but you need good cooling and you will not get the overclocking that this CPU can do.
You will pay more for a K chip that a non K so you will only get the non K performance on a K chip.
so if i decide to go with the i7700 it will work? also even with the 7700 it says i need a bios update. How and when do i do the bios update?
yes the 7700 with work good you will need to update the bios before you install the new cpu
will updating the bios for the i7-7700 mess with my cpu rn?
nop
